part numbers for AE86 brake stuff wanted!
08-31-2006, 10:16 AM
Now i can finally swap the Hachi struts, i started to rebuild the front struts.
I need some part numbers, but my EPC doesn't want to cooperate, so if any of you can give me the following numbers, i'd be very glad ![]() Front discs Front pads calliper rebuild kit brake piston (if not included in some kind off rebuild kit) i once earlier asked about the rebuild kit, and this should be this number, right? Front cylinder Kit: 04479-14060 "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
08-31-2006, 11:36 PM
I can't help you with the Toyota numbers but i am going to by my rotors, pads and brake rebuildkit by Max Miswa.
He has a topic http://www.aeu86.org/viewtopic.php?t=3323 The rotors are 25 dollar per piece, the front caliber rebuild kit is 20 dollar, and he has several brakepads. I do not know what the original Toyotaparts cost here in Holland, but i know this is cheaper!! |
09-01-2006, 12:20 AM
I ordered my brake parts at this online shop: http://www.autopartsonline.nl/nl/index.p...eight=1024
I remember they had pretty decent prices and fast shipping aswell. They do sell just normal brake pads, good stuff for road use, but worthless for serious track use. But the rotors I'm very happy with, as good as OEM I'd say. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-01-2006, 06:54 AM
Front disc; 43512-12130
Pads; >05-85 04465-12370, 05-85> 04465-12070 Brake piston; 47731-14070 Rebuild kit; 04479-14060 |
09-04-2006, 12:10 AM
tnx!
Ordered the parts! While i was strippng down the struts, i found out that the backplates (the ones that keeps stones/dust/other shit away from the disc) are pretty FUBAR, so i need those things aswell, anyone can get me the part numbers of those things? "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
09-04-2006, 07:12 AM
47704-12110 (links) en 47703-12110 (rechts)
09-04-2006, 11:04 AM
tnx again!
09-04-2006, 12:54 PM
some question.
I am going to change my brakepad. My question is, do I need new Pad support plate, anti-ratle spring, pad guide plate and anti- squeal shim? Mine look very rust... I wonder if they still can be used 1985 AE86 (ハチロク) Levin - Summer time daily driver |
part numbers on standard cams | Alex170984 | 10 | 11,248 |
09-19-2013 02:53 PM Last Post: pack |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 6,142 |
Brake master cylinder for FC3S brake conversion | Hachi Go | 8 | 14,604 |
03-03-2011 12:06 AM Last Post: filh |
Urgent. AE86 Door hinge bolt numbers. Need help | hachirokuGTV | 2 | 5,458 |
09-19-2010 08:16 PM Last Post: hachirokuGTV |
endless brake pads part number | Jango_Fett | 2 | 5,369 |
10-14-2009 05:54 PM Last Post: Jango_Fett |
