part numbers for AE86 brake stuff wanted!
08-31-2006, 10:16 AM
Now i can finally swap the Hachi struts, i started to rebuild the front struts.
I need some part numbers, but my EPC doesn't want to cooperate, so if any of you can give me the following numbers, i'd be very glad Smile
Front discs
Front pads
calliper rebuild kit
brake piston (if not included in some kind off rebuild kit)
i once earlier asked about the rebuild kit, and this should be this number, right?
Front cylinder Kit: 04479-14060
08-31-2006, 11:36 PM
I can't help you with the Toyota numbers but i am going to by my rotors, pads and brake rebuildkit by Max Miswa.
He has a topic http://www.aeu86.org/viewtopic.php?t=3323
The rotors are 25 dollar per piece, the front caliber rebuild kit is 20 dollar, and he has several brakepads.
I do not know what the original Toyotaparts cost here in Holland, but i know this is cheaper!!
09-01-2006, 12:20 AM
I ordered my brake parts at this online shop: http://www.autopartsonline.nl/nl/index.p...eight=1024
I remember they had pretty decent prices and fast shipping aswell. They do sell just normal brake pads, good stuff for road use, but worthless for serious track use. But the rotors I'm very happy with, as good as OEM I'd say.
09-01-2006, 06:54 AM
Front disc; 43512-12130
Pads; >05-85 04465-12370, 05-85> 04465-12070
Brake piston; 47731-14070
Rebuild kit; 04479-14060
09-04-2006, 12:10 AM
tnx!
Ordered the parts!
While i was strippng down the struts, i found out that the backplates (the ones that keeps stones/dust/other shit away from the disc) are pretty FUBAR, so i need those things aswell, anyone can get me the part numbers of those things?
09-04-2006, 07:12 AM
47704-12110 (links) en 47703-12110 (rechts)
09-04-2006, 11:04 AM
tnx again!
09-04-2006, 12:54 PM
some question.
I am going to change my brakepad. My question is, do I need new
Pad support plate, anti-ratle spring, pad guide plate and anti- squeal shim?
Mine look very rust... I wonder if they still can be used
  part numbers on standard cams Alex170984 10 10,608 09-19-2013 02:53 PM
Last Post: pack
  Rear ae86 rear discs & pad part numbers? J-86 4 5,801 11-30-2012 06:32 PM
Last Post: J-86
  Brake master cylinder for FC3S brake conversion Hachi Go 8 14,071 03-03-2011 12:06 AM
Last Post: filh
  Urgent. AE86 Door hinge bolt numbers. Need help hachirokuGTV 2 5,156 09-19-2010 08:16 PM
Last Post: hachirokuGTV
  endless brake pads part number Jango_Fett 2 5,131 10-14-2009 05:54 PM
Last Post: Jango_Fett
