part numbers needed
02-09-2005, 12:16 AM
part numbers needed
Does anybody know the part numbers for the parts i show in the foto?
AE86 FANATIC!!! |
02-10-2005, 09:15 AM
part numbers needed
They should be labeled somewhere on the part.... just take the part off your car and look.
"Sometimes giving up isn't the answer we're looking for, but its the only answer we have" |
02-10-2005, 10:57 AM
part numbers needed
I was going to look it up on the EPC for you, but i notice it is maybe a US spec car, don't suppose you can provide the VIN so i can look it up more accurately.
02-10-2005, 02:34 PM
part numbers needed
You might want to look at this
eBay Side Light Hi jacking the tread a bit, did someone want 270cc fuel injectors ? eBay injectors ![]() |
02-10-2005, 02:39 PM
part numbers needed
@ JonT: I can give you the chassis number
AE86-0274966 TYPE: AE86L-ECMQF My EPC disks show "not applicable" for that part maybe because they are for European models only (The Trueno is Canadian) I hope i helped you! ![]() AE86 FANATIC!!! |
02-10-2005, 02:58 PM
part numbers needed
You could try sending Senna on this forum a PM, he has the US trueno front on his coupe so he might be able to take a peek at the numbers.
Also, I'm pretty sure all the part numbers you are looking for can be found on club4ag. FABRICA MI DIEM, PVNC! |
02-10-2005, 03:13 PM
part numbers needed
Thanks a lot Ivan! Much obliged...
part numbers on standard cams | Alex170984 | 10 | 11,296 |
09-19-2013 02:53 PM Last Post: pack |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 6,182 |
Urgent. AE86 Door hinge bolt numbers. Need help | hachirokuGTV | 2 | 5,476 |
09-19-2010 08:16 PM Last Post: hachirokuGTV |
KYB AGX part numbers | eight-six | 5 | 11,526 |
07-02-2009 11:16 AM Last Post: eight-six |
Koyo Bearings Part Number (Needed) | Lipinhu | 10 | 22,257 |
12-22-2008 03:48 AM Last Post: 20vWill |
