KYB AGX part numbers
06-30-2009, 12:33 PM
Trying to help a mate out and sort some adjustable dampers for his 86.
Just trying to get some prices on KYB AGX shocks as there is a company locally to me that are the main retailers in the UK. I gave them the following details ... 90-95 SW20 MR2 front inserts part # 765015 and 82-02 Camaro rears part # 743019 Only issue is the pt number for the 82-02 Camaro rears dont show up on their system. The guy called KYB direct and they advise its not a valid part number? Can anyone else confirm if I have the pt number right? Cheers James ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
07-01-2009, 07:40 AM
Camaro rears part #743019 still shows in the KYB USA on-line catalog
(http://showmetheparts.com/kyb/). But they are a USA market product and probably not listed in other markets. I had to order mine from the USA direct, as the local agents didn't want to know. Cheers... jondee86 |
07-01-2009, 10:51 PM
Cheers for the response Jon, much appreciated!
Checked out Summit and they have the rears, and also the fronts at almost half price. ![]() I presume the fronts will just slot into a set of struts already converted for coil overs? Cheers James ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
07-02-2009, 09:05 AM
I got mine from http://www.shox.com for a good price.
Rears are a straight bolt on with no mods required. Fronts drop into a shortened OEM strut. They are about 60 mm shorter than stock, and I cut the strut by 40 mm and used a 20 mm spacer under. The only possible problem is that the OEM gland nut does not fit the AGX. I had to get mine opened up a bit by a machine shop, so that they would properly "cup" the top of the insert. Cheers... jondee86 |
07-02-2009, 11:16 AM
Awesome help as always Jon!
Cheers ![]() ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
part numbers on standard cams | Alex170984 | 10 | 11,283 |
09-19-2013 02:53 PM Last Post: pack |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 6,166 |
Urgent. AE86 Door hinge bolt numbers. Need help | hachirokuGTV | 2 | 5,469 |
09-19-2010 08:16 PM Last Post: hachirokuGTV |
AGX dampers | Eric | 21 | 21,437 |
05-28-2009 02:42 PM Last Post: Rosedrift |
VIN numbers for various AE86 versions ? | Uzelac | 2 | 5,006 |
10-07-2008 04:48 PM Last Post: banpei |
