KYB AGX part numbers
06-30-2009, 12:33 PM
Trying to help a mate out and sort some adjustable dampers for his 86.
Just trying to get some prices on KYB AGX shocks as there is a company locally to me that are the main retailers in the UK. I gave them the following details ... 90-95 SW20 MR2 front inserts part # 765015 and 82-02 Camaro rears part # 743019 Only issue is the pt number for the 82-02 Camaro rears dont show up on their system. The guy called KYB direct and they advise its not a valid part number? Can anyone else confirm if I have the pt number right? Cheers James http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
07-01-2009, 07:40 AM
Camaro rears part #743019 still shows in the KYB USA on-line catalog
(http://showmetheparts.com/kyb/). But they are a USA market product and probably not listed in other markets. I had to order mine from the USA direct, as the local agents didn't want to know. Cheers... jondee86 |
07-01-2009, 10:51 PM
Cheers for the response Jon, much appreciated!
Checked out Summit and they have the rears, and also the fronts at almost half price. Need to check their shipping and international handling charges which tend to screw things up. I presume the fronts will just slot into a set of struts already converted for coil overs? Cheers James http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
07-02-2009, 09:05 AM
I got mine from http://www.shox.com for a good price.
Rears are a straight bolt on with no mods required. Fronts drop into a shortened OEM strut. They are about 60 mm shorter than stock, and I cut the strut by 40 mm and used a 20 mm spacer under. The only possible problem is that the OEM gland nut does not fit the AGX. I had to get mine opened up a bit by a machine shop, so that they would properly "cup" the top of the insert. Cheers... jondee86 |
07-02-2009, 11:16 AM
Awesome help as always Jon!
Cheers http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
part numbers on standard cams | Alex170984 | 10 | 10,752 |
09-19-2013 02:53 PM Last Post: pack |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 5,889 |
Urgent. AE86 Door hinge bolt numbers. Need help | hachirokuGTV | 2 | 5,225 |
09-19-2010 08:16 PM Last Post: hachirokuGTV |
AGX dampers | Eric | 21 | 20,530 |
05-28-2009 02:42 PM Last Post: Rosedrift |
VIN numbers for various AE86 versions ? | Uzelac | 2 | 4,724 |
10-07-2008 04:48 PM Last Post: banpei |
