part numbers on standard cams
09-16-2013, 10:07 PM
where is the part number on a standard camshaft?
09-18-2013, 06:07 AM
16v cams part numbers:
13501-16010 / 13502-16010 (240) 13501-16030 / 13502-16020 (232) 4age 16v to FR 20VT |
09-18-2013, 11:05 AM
I know what they are, but were is the part number physically on the camshaft?
09-18-2013, 11:22 AM
Alex170984 Wrote:I know what they are, but were is the part number physically on the camshaft? For this info a Proffesor of 4age should answer mate 4age 16v to FR 20VT |
09-19-2013, 07:36 AM
as fas as i informed the part numbers are not written on the cams.No of the ae92 had the 240 durations cams....for sure someone with experience should confirm this!
09-19-2013, 07:53 AM
240 cams where on ae86 corolla only.. then you can see easely that cams have less duration.
09-19-2013, 10:29 AM
I had a corolla engine in my aw11 - does anyone have the dimension of a cam on the 240s i can compare mine too?
09-19-2013, 11:12 AM
Aw11 should have the same 240s cams as the ae86, it's the same engine
09-19-2013, 01:53 PM
My engine was a bit odd really, as its 7 rib, with 20mm pins but 9.4 pistons
Is that an AE92 or AE86 engine and did the camshafts differ? |
09-19-2013, 02:53 PM
I don't think the reference number is engraved on the cams....!
Shim size for AM cams | kazi | 4 | 5,205 |
Toda Cams | Alex170984 | 7 | 8,652 |
02-11-2017 05:50 PM Last Post: Alex170984 |
20V cams - CATCAMS vs KELFORD? | Grant | 19 | 38,840 |
11-19-2015 07:45 AM Last Post: hachirokkos |
cams cams cams | megabob | 60 | 56,876 |
12-31-2013 01:19 AM Last Post: gze spec |
4age 16v 1st and 2nd generation cams and not only difference | Apsogos | 3 | 7,605 |
09-16-2013 08:24 AM Last Post: Apsogos |
