pinion adjustment
11-10-2010, 07:45 PM
pinion adjustment
Gentlemen I thank you for your patience.
I have decided instead to adjust the top arms as this appears to be the correct way to do it and 4mm should bring the propshaft straight with the pinion at the moment the pinion is facing down.
I will start with it straight and go from there unless anyone has any suggestions, remembering that it is a single piece prop. and seems prone to vibration.
11-10-2010, 08:35 PM
pinion adjustment
I have a question.
Can this problem be solved with traction brackets?
[Image: AEU86 AE86 - pinion adjustment]
Vladimir
N/A for life...
11-10-2010, 09:08 PM
pinion adjustment
You know that you don't necessarily want the pinion level right? Just parallel to the gearbox output shaft (more or less).
You really need to read up on pinion/U-joint angles before you start adjusting things. If you haven't already that is.
Traction brackets shouldn't do much for pinion angle...but I could imagine them having some kind of influence.
11-10-2010, 10:38 PM
pinion adjustment
Yes there is a good article on club 4age about pinion angles although I think some people confuse pinion angle and axle bracket angle when they are discussing traction and pinion angle.
11-11-2010, 03:58 AM
pinion adjustment
You do NOT want to put the driveshaft 'inline' with the pinion angle. That's a good way to destroy your u-joints.
You want the pinion angle parallel with the engine/transmission angle.
Andrew
11-12-2010, 01:13 AM
pinion adjustment
assassin10000 Wrote:That's a good way to destroy your u-joints.
Thanks for trying.
I can't see this getting any better.
11-12-2010, 10:46 AM
pinion adjustment
assassin, yes I think I was trying to say that Blush
  Handbrake adjustment discs? DMC 8 2,070 03-10-2024 08:08 PM
Last Post: DMC
  DIY: a quick outline on why & how to set pinion angle. assassin10000 9 18,702 12-21-2016 10:28 PM
Last Post: ditn
  Camber adjustment vs original struts Lt86 9 9,694 05-07-2015 09:45 PM
Last Post: zenki
  Ring & pinion ratio. izanagi 27 28,120 07-05-2014 07:35 PM
Last Post: assassin10000
  axle swap time how capable is a std crownwheel and pinion fax0815 32 47,177 09-26-2013 08:33 PM
Last Post: Lajoosh
