power loss
04-21-2005, 12:12 PM
power loss
recently my 4age engine seems to have lost all its power and i cant figure out why. the car is very rarely driven and is garaged a lot. it seems like it is a one litre or something
04-21-2005, 01:44 PM
power loss
whats the oil pressure like?
is she ticking over ok?
04-21-2005, 01:55 PM
power loss
oil pressure is fine, and its ticking over fine, its just when i drive it that i notice anything.
04-21-2005, 02:22 PM
power loss
Check ignition, distributor cap, maybe you have water condensat in it.
1984 AE 86 Levin hatchback
1989 AE 92 GTi
2004 Kawasaki KLE 500
04-21-2005, 05:56 PM
power loss
i think its your oil...its old and maybe needs a change.......
[Image: AEU86 AE86 - power loss]
04-21-2005, 06:41 PM
power loss
I think your injectors are faulty.
ae86
Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100
Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100
KTM 950 SE ->100 3,2 sec 105 Db Tongue
xt660r ->100 4,5 sec
BMW 1100 GS->100 4 sec
04-21-2005, 10:04 PM
power loss
why wouldyou say the injectors are faulty, is it a big job to fix
04-21-2005, 10:24 PM
power loss
faulty or dirty trough old benzine.
cleaning by adding a cleaning solvent .
Or by ussing a ultrasoon unit.
04-21-2005, 11:13 PM
power loss
I would let the ECU run a diagnostic check as well just to make sure it's not something in the electronics. Maybe check out if ignition timing is still correct.
04-25-2005, 11:42 AM
power loss
Kas Wrote:Check ignition, distributor cap, maybe you have water condensat in it.
the distributor is fine, although i think the rubber o ring under the distributor is gone as it is leaking oil. would this have anything to do with it?
  Carbon fibre - weight loss s.bjelke 11 13,400 05-25-2005 11:20 AM
Last Post: JonT
