problem ???
04-30-2007, 01:59 PM
problem ???
Do i have to get worried or what ?
After cleaning the engine-bay i saw at the point the arrow shows that there is a small (1-2mm) gap ... Is it a result of the stiffeness using upper and lower strut bars? Do i have to be worried a lot or is it a small repairable damage ? ![]() AE86 FANATIC!!! |
04-30-2007, 02:14 PM
problem ???
Where does the arrow points?
danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
04-30-2007, 02:16 PM
problem ???
It's the point the chassis meets the frontwall (did i say it right?) ...
AE86 FANATIC!!! |
04-30-2007, 02:45 PM
problem ???
I at least, need a bigger closer photot to see what you mean
04-30-2007, 02:48 PM
problem ???
i 'll try to take a closer one and upload it later on the afternoon ...
AE86 FANATIC!!! |
04-30-2007, 09:23 PM
problem ???
How long is the gap ?
04-30-2007, 10:40 PM
problem ???
i think about a month or so ..
what do you say Jamie ? AE86 FANATIC!!! |
04-30-2007, 11:13 PM
problem ???
ali a gap or a hole ? If the chassis is starting to tear apart than repairing is the first thing you should do. If its a rust hole than well fix it :-)
04-30-2007, 11:20 PM
problem ???
Month ? No no, I'm asking about length of the gap (in sentimeters).
05-01-2007, 05:22 PM
problem ???
this is a closer foto of the gap ...
big trouble ?????? ![]() AE86 FANATIC!!! |
4agZe problem solved - 99% IC problem | Okami | 41 | 36,846 |
07-12-2012 04:49 PM Last Post: Okami |
AC problem? Idle problem? | KD2229 | 3 | 4,910 |
08-19-2009 02:08 AM Last Post: KD2229 |
