rear diff/propshaft clanking/banging at low speed
06-18-2010, 12:11 PM
I have some unsual noise in rear end, diff assembly.
Diff is TRD 2way, new with some 2000-3000 km. Whole rear end was rebuilt with new bearings and stuff. Sometimes, when driving slow i here not so loud metal bang/clang noise. It's connected with changing load on rear end, when i cut off power or push throttle, or press/release clutch. It doesn't happen allways, sometimes, like once in every 10 times i repeat this stuff. Sounds like something hitting a metal, not loud. My car doesn't have rear seats nor any dampening material, and the level of noise isn't loud. Level like normal knocking on wood ... ![]() Diff looks to be ok, it' works ok, there is standard whining at 80+ km/h but i believe it's normal. When we rebuild it, CWP was looking good. It could be propshaft olso, maybe some connection has too much foreplay ? Anyway, where to look, and should i be worried ? Thanks |
06-18-2010, 12:13 PM
it must be the usual noise of the 2way diffs. they are making noise at low speeds.
06-18-2010, 12:17 PM
I know they are making noise while cornering, but this happens when i'm driving straight, city-street drive, slow and with lot's of 1st/2nd gear, slow braking and accelerating.
06-18-2010, 08:19 PM
your car is too low for our street conditions so it hit the asphalt
06-20-2010, 02:03 AM
Errrrrr... no, thats not the problem
![]() I listened more carefull and came to conclusion that its related to press/release of clutch, gears are not important. |
Silver top low idle | AlexFourTwenty | 7 | 10,715 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 15,760 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 31,916 |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 6,187 |
How to: Repair low fuel warning sender | Sanity Clause | 2 | 37,617 |
11-22-2012 09:21 AM Last Post: ZaX |
