rear diff/propshaft clanking/banging at low speed
06-18-2010, 12:11 PM
I have some unsual noise in rear end, diff assembly.
Diff is TRD 2way, new with some 2000-3000 km. Whole rear end was rebuilt with new bearings and stuff. Sometimes, when driving slow i here not so loud metal bang/clang noise. It's connected with changing load on rear end, when i cut off power or push throttle, or press/release clutch. It doesn't happen allways, sometimes, like once in every 10 times i repeat this stuff. Sounds like something hitting a metal, not loud. My car doesn't have rear seats nor any dampening material, and the level of noise isn't loud. Level like normal knocking on wood ... Diff looks to be ok, it' works ok, there is standard whining at 80+ km/h but i believe it's normal. When we rebuild it, CWP was looking good. It could be propshaft olso, maybe some connection has too much foreplay ? Anyway, where to look, and should i be worried ? Thanks |
06-18-2010, 12:13 PM
it must be the usual noise of the 2way diffs. they are making noise at low speeds.
06-18-2010, 12:17 PM
I know they are making noise while cornering, but this happens when i'm driving straight, city-street drive, slow and with lot's of 1st/2nd gear, slow braking and accelerating.
06-18-2010, 08:19 PM
your car is too low for our street conditions so it hit the asphalt
06-20-2010, 02:03 AM
Errrrrr... no, thats not the problem
I listened more carefull and came to conclusion that its related to press/release of clutch, gears are not important. |
Silver top low idle | AlexFourTwenty | 7 | 10,183 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 15,119 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 30,370 |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 5,883 |
How to: Repair low fuel warning sender | Sanity Clause | 2 | 37,043 |
11-22-2012 09:21 AM Last Post: ZaX |
