rear fender rebuilt
04-23-2006, 04:19 PM
rear fender rebuilt
i want to rebuilt the rear fenders.were can i find some new ore used fender "models"?
daily driver avensis 2.0 d4d and Yaris 1.0
weekend driver 1985 AE86
04-24-2006, 01:29 AM
rear fender rebuilt
on this forum..... there is a link for a company in the states that sells the whole rear fender.... Ill try to look it up.
You have by far the ugliest hachi on the nicest rims in the world -Mux213
04-24-2006, 07:12 PM
rear fender rebuilt
There is also this irish dude:
http://www.aeu86.org/viewtopic.php?t=191...ear+panels
[Image: AEU86 AE86 - rear fender rebuilt]
04-24-2006, 10:21 PM
rear fender rebuilt
You can use the fender from a Starlet E7 if you only need the arch...
04-25-2006, 09:39 PM
rear fender rebuilt
Jan Pedersen Wrote:You can use the fender from a Starlet E7 if you only need the arch...
i only need the arch...
04-26-2006, 04:57 AM
rear fender rebuilt
I finally found it
http://www.alfaparts.net/toycor.htm
04-26-2006, 09:04 PM
rear fender rebuilt
Ah, good to know. Smile
Edit: I've added them to the Technical FAQ:
http://www.aeu86.org/viewtopic.php?p=35508#35508
  Rear ae86 rear discs & pad part numbers? J-86 4 6,157 11-30-2012 06:32 PM
Last Post: J-86
  Question: Where I can find this fender flare? winchi.c 3 5,413 05-01-2011 09:58 AM
Last Post: Bentley
  fender holes measure HELP sergiocharged 11 11,784 12-24-2010 04:08 PM
Last Post: aussiefan
  I need some info about the plastic under the 2 front fender Mattolo 4 5,864 02-22-2010 01:28 PM
Last Post: Mattolo
  Adjustable Rear trailing arm/rear 4 links? lolali 1 4,823 10-03-2009 05:17 PM
Last Post: lolali
