snapped water pump
02-05-2007, 09:46 PM
snapped water pump
Okay, here's the deal. my boyfriend has a '84 sr5 w/ a 3 tc. He recently replaced the water pump twice. Both times when the car was revved hard it snapped the front of the water pump. The first water pump had thinner metal and the second was thicker but both snapped liked twigs when revved hard (like 6,000 rpms) Like the whole front metal piece gives way. He changed the fan out to a different fan. It's not electric. but he keeps having to change the water pump because it snaps. He only tightens it down by hand and it doesn't seem too tight. His alternator is starting to fail. it's overcharging the battery. He thinks that the problem could be caused by the pulley attached to the water pump is bent or possibly the fan is bent/ not running straight. Neither of us can figure out exactly why it keeps doing this. Any ideas on what could be causing this???
02-05-2007, 09:49 PM
snapped water pump
That sounds like a strange problem, it must have to do with to much tension on the axle somehow. Though with overcharging it could also be that its overrevving (even if the engine is not) due to a wrongly sized pully.
Which I could be of serious help but there is not much I know about the 3tc, I hope someone else on the forum knows more about it Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
02-05-2007, 10:10 PM
snapped water pump
hmmz make a picture of the pulley's with sizes in diameters. They should difer from standard 4age ones :-D
02-06-2007, 12:34 AM
snapped water pump
Double check are they 4AGE for AE86 or 4AGE for FWD cars ?
20v BT - which oil pump? | Mylesmck | 4 | 2,858 |
Fuel pump issue | DJexor | 11 | 5,276 |
Cam Cap Bolt Snapped!! | Alex170984 | 1 | 3,766 |
06-08-2018 01:17 PM Last Post: Ivan141 |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 7,666 |
12-06-2017 06:48 PM Last Post: Bean |
fuel line hose from the pump | Wikizz | 4 | 6,091 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
