spring diameter
07-17-2009, 07:00 PM
spring diameter
kan someone tell me the diameter from an ae86 spring?
07-18-2009, 04:30 AM
spring diameter
The front springs are 140mm at the bottom and then goes into a 112mm at the top.
Cheers
07-18-2009, 08:02 AM
spring diameter
Thanx!
  SOME 4AG valve spring specs oldeskewltoy 5 13,786 05-04-2015 01:17 PM
Last Post: Project D
  clutch pedal return spring Eifelaner 2 7,455 09-06-2013 10:21 AM
Last Post: Apsogos
  Piston Diameter Alex170984 11 15,433 02-07-2013 12:52 AM
Last Post: fax0815
  P-valve CLOSED --> Stiffer spring will do it :) Dino86 1 3,367 04-05-2012 04:17 PM
Last Post: Dino86
  lowering spring information HELP martyg 1 3,541 09-27-2011 01:56 PM
Last Post: martyg
