spring diameter
07-17-2009, 07:00 PM
spring diameter
kan someone tell me the diameter from an ae86 spring?
07-18-2009, 04:30 AM
spring diameter
The front springs are 140mm at the bottom and then goes into a 112mm at the top.
Cheers |
07-18-2009, 08:02 AM
spring diameter
Thanx!
| SOME 4AG valve spring specs | oldeskewltoy | 5 | 15,155 |
05-04-2015 01:17 PM Last Post: Project D |
| clutch pedal return spring | Eifelaner | 2 | 8,305 |
09-06-2013 10:21 AM Last Post: Apsogos |
| Piston Diameter | Alex170984 | 11 | 17,611 |
02-07-2013 12:52 AM Last Post: fax0815 |
| P-valve CLOSED --> Stiffer spring will do it :) | Dino86 | 1 | 3,999 |
04-05-2012 04:17 PM Last Post: Dino86 |
| lowering spring information HELP | martyg | 1 | 4,018 |
09-27-2011 01:56 PM Last Post: martyg |
