spring length
04-13-2009, 08:05 PM
spring length
Hi there
Does anybody know what length and diameter are stock springs ?
Eibachs, TRD ?
Tried to search but everybody is talking about how much they lower the ride, not really how long are they.
Trying to figure out what 2.5" ID springs to order to match with SS shocks.
Thanks
04-13-2009, 10:33 PM
spring length
The free height for the standard rear springs is 327mm, installed height is 219mm. The TRD race springs are 205-219mm free, 170mm installed.
04-14-2009, 12:17 AM
spring length
TRD race, which one ? 6kg or even 7kg per mm ?
Thanks!
04-14-2009, 09:13 AM
spring length
Uzelac Wrote:TRD race, which one ? 6kg or even 7kg per mm ?
All of them. Smile The spring length is within the 205-219mm range, depending on the spring rate (4.3kg/mm to 9.0kg/mm).
04-14-2009, 09:36 PM
spring length
Haha.. great Smile
And some dimensions for the front ?
Thanks
04-15-2009, 10:04 AM
spring length
The standard front spring is 248mm free, 185mm installed and has a spring rate of 4.3kg/mm. The TRD N2 cars used short-stroke coilover struts with 74mm ID springs 226-236mm free, 190mm installed. These were available in spring rates varying from 4.6kg/mm to 10.0kg/mm.
04-25-2009, 08:10 PM
spring length
firehawk Wrote:The standard front spring is 248mm free, 185mm installed and has a spring rate of 4.3kg/mm.
Standard OEM, lowering or some TRD ?
BTW. I presume the much bigger difference of lowering in rear what makes all TRD equiped AE86 go to "nose-up-bottom-down" position Smile
Thanks once again
04-25-2009, 11:24 PM
spring length
Standard OEM front -380mm free and 1.8kg/mm
Standard OEM rear -360mm free and 2.2kg/mm
http://www.driftclub.rs
  Rear arm length totta Crolla 7 3,431 06-05-2024 08:53 AM
Last Post: totta Crolla
  SOME 4AG valve spring specs oldeskewltoy 5 15,726 05-04-2015 01:17 PM
Last Post: Project D
  4AGE 20v Ignition Lead Length mad.matt 3 8,292 10-01-2014 03:43 PM
  Door length Ivan141 3 6,335 03-18-2014 02:11 PM
  ae86 crush sleeve length choyr 15 24,922 02-26-2014 05:03 PM
Last Post: choyr
