spring question
09-28-2006, 09:52 PM
spring question
Hi Guys.
I have a little question I am driving a Koni setup with 40mm loweringsprings... the setup drives perfect but I am not happy with the 40mm lowering... I am looking for 70mm or something like that.. any sugestions wich springs i can use? TRD? SPIRT? here is apic so you know what i meen. |
09-28-2006, 10:13 PM
spring question
09-28-2006, 10:46 PM
spring question
Ah my thread is getting famous, thanks djex
Julian, read the thread Djexor pointed at, all the info you need you will find is in there. In a nut shell, both TRD springs and Swift springs will give you the lowering you seek, but your current shocks and strut setup will cause you alot of ride problems. You will need alot of other modifications like getting short stroke shocks, shortening your front struts, RCA's, shortend or adjustable Panhard rod, etc. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
SOME 4AG valve spring specs | oldeskewltoy | 5 | 13,235 |
05-04-2015 01:17 PM Last Post: Project D |
clutch pedal return spring | Eifelaner | 2 | 7,110 |
09-06-2013 10:21 AM Last Post: Apsogos |
P-valve CLOSED --> Stiffer spring will do it :) | Dino86 | 1 | 3,168 |
04-05-2012 04:17 PM Last Post: Dino86 |
lowering spring information HELP | martyg | 1 | 3,373 |
09-27-2011 01:56 PM Last Post: martyg |
clutches and spring washers position in 2 Way TRD diff???? | T_AE86 | 3 | 5,079 |
09-01-2011 10:50 AM Last Post: T_AE86 |
