stalling
05-02-2008, 03:17 AM
stalling
Hey guys
Iam having touble where when u let of the throttle the car should idle but the revs drops and stalls could it be the ignition timing ? thx |
05-02-2008, 09:57 AM
stalling
Not likely to be ignition timing, it's more likely to have starting problems in that case (at least if it has too much advance).
I once had this problem on an engine that had broken pistonrings on 2 cilinders, not saying that's your problem in this case though. You can rule this out by pulling the crankcase ventilation tube off the valve cover, and give it some throttle. If it blows smoke out with some force, then your in trouble. FABRICA MI DIEM, PVNC! |
05-02-2008, 12:34 PM
stalling
have you also checked your water level in your radiator?
05-02-2008, 02:17 PM
stalling
kk well first im gonna change the timng back to stock (waiting for the timing light to arrive
05-03-2008, 12:56 AM
stalling
well sort of done it. its better but still the revs drop below 500 rpm and then pumps back up
