stand alone ECU but i want to keep my rev clock
02-18-2010, 04:51 PM
Hi All.
I'm putting ITB's on my AE86 with a stand alone ECU but i want to keep my rev clock ![]() ![]() Drive it like your late for mass and god is your passenger / don’t just bend the rules rule the bends fun ant in a straights!! |
02-18-2010, 08:42 PM
without knowing, but using common sense.
The signal should originale off your coil. Kp62 - 135hp Ae86 - 135hp C32 Laurel - 440hp C32 Laurel - 125hp ![]() |
02-18-2010, 09:12 PM
williep12 Wrote:Hi All. Check the documentation for your ECU. On the one I am using, you can configure one of the unused ignition outputs as a tacho output. Cheers... jondee86 |
02-18-2010, 11:37 PM
Ordinarily your tach signal should be coming from the negative terminal on your ignition coil. If your sticking with original ignition you should be fine as long as you dont remove the wire.
As Jondee said, most aftermarket ECU's can output a tach signal as well.. FABRICA MI DIEM, PVNC! |
02-19-2010, 08:53 PM
thanks lads ye the ECU wire isn,t the problem but what wire do i tag it to
02-19-2010, 09:37 PM
williep12 Wrote:thanks lads ye the ECU wire isn,t the problem but what Have a read here.... http://www.aeu86.org/viewtopic/map-harne...ewall+plug Cheers... jondee86 |
02-21-2010, 03:11 PM
williep12 Wrote:Hi All. im using a standalone ecu, you will have to use your standard ecu 2 so that you will be able to use your rev clock, wont affect you at all |
02-21-2010, 10:51 PM
Think about it for a while... if your not changing ignition parts, and the tach wire of the original is coming from the negative coil terminal, then you dont need to change a thing!
You dont need you standard ecu because it is not supplying the tach signal. FABRICA MI DIEM, PVNC! |
02-22-2010, 09:20 PM
Ivan141 Wrote:Think about it for a while... if your not changing ignition parts, and the tach wire of the original is coming from the negative coil terminal, then you dont need to change a thing! well i had toi use standard ecu |
02-22-2010, 09:31 PM
Why?
![]() A wheel to steer the front of the car A pedal to steer the rear |
Engine starts/revs but no idle | GenkiMotors | 17 | 8,067 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
Carb conversion but what is this and how ? | Allexz | 5 | 8,751 |
05-24-2016 08:48 AM Last Post: Allexz |
Raising the rev limit on stock ECU | fax0815 | 2 | 11,192 |
08-31-2015 02:04 PM Last Post: gon |
4age 16v oem ecu rev limiter research | ditn | 18 | 29,170 |
06-22-2015 08:02 AM Last Post: ditn |
getting new sparkplugs, or keep away ? | MC_JP | 5 | 6,479 |
09-19-2014 11:35 PM Last Post: Project D |
