steering wheel removle
03-15-2007, 01:58 AM
I have this one from LevinGT:
First loosen the nut. Not entirly, just a bit. Grab your steeringwheel with both hands. press a bit with your right hand on the steeringwheel, while pulling your left hand hard in your direction. It worked for me.
[Image: AEU86 AE86 - steering wheel removle]
03-15-2007, 02:53 PM
Mine fell off almost immediately last week, while two weeks ago it wouldn't budge. Only difference is that I didn't tighten the bolt too much: I just screwed it on again with my fingers, drove the car for a week and presto: it is loose! Tongue
03-15-2007, 07:54 PM
Lipinhu Wrote:Loosen the bolt, and with your hands and fast moves, hit the steering wheel from the back to you, try to alrtenate the "hits" left/right. It has to come out.
Ding Ding Ding! Thumbs up! You are correct.
Peter Diaz
http://www.shiftgearclothing.com
http://www.ectoyotas.com/forum/
http://www.facebook.com/elfatherae86
03-16-2007, 01:38 AM
force never did anything for me.. what i think happens is that the pinion onto which the wheel is attached is a very tight fit, any pulling in the slightly wrong direction generates to much friction so its hard to pull off. only pulling it straight up 90 degrees will resoult in effortles removal. this was always the key for me..
03-16-2007, 06:06 PM
It's not the force that counts, it's the shock of the impact. The steering wheel has conical splines, meaning that the tighter you tighten the nut, the harder it will jam itself stuck. Bit the same like the steering knuckles.. you either need to 'shock' them apart, and if that fails, a puller is necessary.
03-16-2007, 10:25 PM
Just need to take off the bolt and give a strong punch in the steering wheel
Always on top always on sideways
http://img512.imageshack.us/img512/6080/...tomrx5.jpg
  steering wheel - leather painting kit Gtsi-R 4 2,271 02-14-2022 03:00 PM
Last Post: decryphe
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 43,356 10-02-2014 06:07 PM
  DIY: How We Can Rescue The OEM JDM Steering Wheel Serencebey 16 20,903 03-28-2010 07:41 AM
Last Post: Serencebey
  steering wheel/boss/quick release questions Eric 11 12,332 08-19-2008 09:35 AM
Last Post: cavey
  window removle matto 2 3,583 05-25-2007 07:03 PM
Last Post: robokill
