stock cam specs???
03-20-2008, 08:48 PM
stock cam specs???
what are the stock cam specs in a 4age? the lobe duration to be exact
Slide to side worldwide!! |
03-20-2008, 10:10 PM
stock cam specs???
240 bluetop 230 redtop
03-20-2008, 11:58 PM
stock cam specs???
TVIS cams - 240 gross duration, duration @.050" lift is 204. Lift is 7.52mm
smallport cams - 232 gross duration, duration @.050" lift is 196. Lift is 7.1mm TVIS cams are identical timing... 9 to 51 intake, 51 to 9 exhaust non TVIS cams are different timing from intake to exhaust. Intake is 8 to 44, while the exhaust timing is 47 to 5 Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-21-2008, 08:02 AM
stock cam specs???
Quote:non TVIS cams are different timing from intake to exhaust. To save me struggling with the maths... can you say what lobe centrelines these numbers would produce ?? I set mine to 110/110 and it runs fine. But I will be hitting the dyno next week, and would like to have the cams set at factory centrelines to create a true baseline dyno chart. Cheers... jondee86 |
03-21-2008, 01:55 PM
stock cam specs???
thanks, i was just wondering
03-25-2008, 11:31 PM
stock cam specs???
jondee86 Wrote:Quote:non TVIS cams are different timing from intake to exhaust. Do you have the TRD Bible? It is inside the AE92 race manual..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-26-2008, 11:11 PM
stock cam specs???
As it happens, it is easy enough to work out.
TVIS cams 111/111 deg lobe centres Non-TVIS cams 108 intake and 111 exhaust lobe centres. I'm going to leave mine at 110/110 as the new cams are optimised for TVIS motors, but I am installing into a non-TVIS motor. I'll post up the results Cheers... jondee86 |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,437 |
82mm Stock compression Pistons | apardal | 4 | 2,874 |
AE86 Battery specs | hachirokuGTV | 9 | 16,630 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,591 |
Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 5,675 |
