stock cam specs???
03-20-2008, 08:48 PM
stock cam specs???
what are the stock cam specs in a 4age? the lobe duration to be exact
Slide to side worldwide!!
[Image: AEU86 AE86 - stock cam specs???]
03-20-2008, 10:10 PM
stock cam specs???
240 bluetop 230 redtop
03-20-2008, 11:58 PM
stock cam specs???
TVIS cams - 240 gross duration, duration @.050" lift is 204. Lift is 7.52mm
smallport cams - 232 gross duration, duration @.050" lift is 196. Lift is 7.1mm
TVIS cams are identical timing... 9 to 51 intake, 51 to 9 exhaust
non TVIS cams are different timing from intake to exhaust. Intake is 8 to 44, while the exhaust timing is 47 to 5
Dan -
03-21-2008, 08:02 AM
stock cam specs???
To save me struggling with the maths... can you say what lobe
centrelines these numbers would produce ?? I set mine to 110/110
and it runs fine. But I will be hitting the dyno next week, and would
like to have the cams set at factory centrelines to create a true
baseline dyno chart.
Cheers... jondee86
03-21-2008, 01:55 PM
stock cam specs???
thanks, i was just wondering
03-25-2008, 11:31 PM
stock cam specs???
Cheers... jondee86
Do you have the TRD Bible? It is inside the AE92 race manual.....
Dan -
03-26-2008, 11:11 PM
stock cam specs???
As it happens, it is easy enough to work out.
TVIS cams 111/111 deg lobe centres
Non-TVIS cams 108 intake and 111 exhaust lobe centres.
I'm going to leave mine at 110/110 as the new cams are optimised
for TVIS motors, but I am installing into a non-TVIS motor. I'll post
up the results Smile
Cheers... jondee86
  Digital speedometer on stock dashboard FanIsHere 0 1,388 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 2,815 11-24-2021 04:26 PM
Last Post: apardal
  AE86 Battery specs hachirokuGTV 9 16,454 03-13-2020 04:16 PM
Last Post: Power_uP
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,459 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,603 03-24-2019 04:10 PM
