surgin when u throttle help
11-27-2009, 03:15 AM
hello fellas im a new member and i did an sr5 to gts convertion car starts fine idles fine till u give it some throttle or gas it starts surgin up n down wont let me drive it any clues thanks
11-27-2009, 09:41 AM
Often the cooling system is responsible for surging (at idle though)..
The TPS can also cause similar problems.
11-27-2009, 09:52 AM
check for leaks in/around the intakeplenum
11-28-2009, 03:00 AM
tps guys tps thanks i slept on it and found the problem $140 for a new one
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 11,460 10-25-2013 05:13 PM
Last Post: Apsogos
  throttle conversion hygneji 4 4,906 11-12-2009 10:18 AM
  AE101 throttle body on an AE86 what ECU? megabob 7 8,734 11-09-2009 09:12 AM
  16v to 20v throttle body's TPS lolali 4 9,543 10-21-2009 01:04 PM
Last Post: isac
  Throttle question???????? ash16valve 6 5,915 08-25-2009 05:34 PM
Last Post: ash16valve
