surgin when u throttle help
11-27-2009, 03:15 AM
hello fellas im a new member and i did an sr5 to gts convertion car starts fine idles fine till u give it some throttle or gas it starts surgin up n down wont let me drive it any clues thanks
11-27-2009, 09:41 AM
Often the cooling system is responsible for surging (at idle though)..
The TPS can also cause similar problems. FABRICA MI DIEM, PVNC! |
11-27-2009, 09:52 AM
check for leaks in/around the intakeplenum
AE86 ex-daily |
11-28-2009, 03:00 AM
tps guys tps thanks i slept on it and found the problem $140 for a new one
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 11,141 |
10-25-2013 05:13 PM Last Post: Apsogos |
throttle conversion | hygneji | 4 | 4,764 |
11-12-2009 10:18 AM Last Post: Ivan141 |
AE101 throttle body on an AE86 what ECU? | megabob | 7 | 8,430 |
11-09-2009 09:12 AM Last Post: Ivan141 |
16v to 20v throttle body's TPS | lolali | 4 | 9,282 |
10-21-2009 01:04 PM Last Post: isac |
Throttle question???????? | ash16valve | 6 | 5,705 |
08-25-2009 05:34 PM Last Post: ash16valve |
