t3 coilover front
01-07-2011, 11:34 AM
t3 coilover front
I have a set of weldon coilovers from t3 on my car, with i think mr2sw20 short stroke rear dampers. But the set is worthless to drive with..
the dampers are way to soft.. every little bump in the road cause my dampers to max out. what other kind of dampers can i use? what kind of dampers do others use? |
01-07-2011, 12:06 PM
t3 coilover front
What exactly do you have? Fill in this list
Front shocks (brand, type): Front strut housing (length): Front spring (kg/mm): Front ride height (pic?): Front bump stop type: Rear shock (brand): Rear spring: Rear ride height: Rear bump stop type: Wheel width: Tire size: I highly doubt that the dampers are your problem :E A wheel to steer the front of the car A pedal to steer the rear |
01-07-2011, 01:09 PM
t3 coilover front
why do you doubt my dampers are the problem?
Front shocks (brand, type): sw20 short stroke, dint know the brand anymore, bought them form the aeu86 shop. Front strut housing (length): std. with T3 strut tube spacer Front spring (kg/mm): t3 ground control set Front ride height (pic?): http://sphotos.ak.fbcdn.net/hphotos-ak-a...3573_n.jpg Front bump stop type: dunno what that is. Rear shock (brand): blue ones that came with the car Rear spring: apex lowering spring, cut of 3 rings Rear ride height: si previous pic Rear bump stop type: again, dont know what that is Wheel width: 5J Tire size: 195/50/14 |
01-07-2011, 01:53 PM
t3 coilover front
There you go, the shocks aren't your problem :!:
Strut tube shortening is done to gain bump/compression stroke on lowered vehicles. You lowered your car, but didn't lower the shock relative to the body. You now have almost no bump travel and even the slightest bump will send your suspension into the bump stops. This, as you have noticed, sucks donkey-balls. Basically, the T3 strut tube spacers suck in every way imaginable. Its something I've said over and over again. You now have two options: shorten those struts, or if you don't believe me, first raise the car to original height (5cm or so) and come back and tell me how it handles. I can guarantee you that it will be a different car. And if you dont believe me, send me the shocks, I'll be more then willing to drop them into my shortened cartridges and hand you the keys for a short ride. then again...maybe not, since you'll probably want them back :wink: A wheel to steer the front of the car A pedal to steer the rear |
01-07-2011, 03:37 PM
t3 coilover front
Well, that actually makes sence
![]() So, the best option for me will be to get the strut tube spacer out and shorten the struts and my problem will be solved? The strut tube spacers looked like an easy fix... But as you say it sucks donkey-balls ![]() |
01-09-2011, 02:31 AM
t3 coilover front
Yeah all you need to do is shorten your strut tubes.
Thats a pritty good guide: 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
01-09-2011, 01:30 PM
t3 coilover front
i know how to do that but i just didnt want to, the strut spacers seemed an easier option, now i know i waisted 60 dollars on crap
![]() thanx for the video! |
01-09-2011, 01:33 PM
t3 coilover front
why did they but a litlle tube under the shocks before they put it in the housing?
toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
01-09-2011, 01:40 PM
t3 coilover front | |||
01-09-2011, 01:53 PM
t3 coilover front
Interesting to read
DIY Coilover | sketchy | 8 | 13,189 |
04-01-2013 11:00 PM Last Post: sketchy |
Coilover shock replacement | phill 92 | 9 | 11,838 |
08-28-2012 08:46 PM Last Post: phill 92 |
Coilover help | phill 92 | 9 | 10,284 |
05-22-2012 01:10 AM Last Post: MCNSPORT.com |
rear COILOVER's | DRFT | 17 | 28,376 |
07-29-2011 10:12 AM Last Post: DRFT |
What is the length of the coilover springs?? | DRFT | 6 | 7,304 |
12-11-2009 12:14 PM Last Post: DRFT |
