tacho issues using haltech e6x on 4ag 20v
06-04-2013, 08:21 PM
Hi, I installed a haltech E6X ECU with a haltech ignition module and twin coils for my 4qag 20v.
the engine is up and running great but my original dash tacho didn't work. Im using my Apexi SAFC as a tacho for now.
Someone told me to use an MSD 8910 adapter to correct this issue so I bought it but when I connected it to one of the coils, the tacho works but shows a wrong RPM reading. Tried to connect it to both coils and the engine didn't work correctly.
I'm kind of lost now...
Any help will be appreciated
thanks!
06-04-2013, 10:59 PM
Do a search for tach signal boosters... you need to either beef up the ECU's tacho output signal or figure out which components to change on the dash to make it respond to lower voltage signals.
06-04-2013, 11:08 PM
i believe this is the same,i also have one made for my 4AGZE ae101 since i wont read the signals either
check the info in the link scroll to the bottom
http://www.ebay.co.uk/itm/DAKOTA-DIGITAL...5655e25c8b
06-05-2013, 07:00 AM
If you can access the negative terminal on both coils, you could make
this for a couple of bux...
[Image: AEU86 AE86 - tacho issues using haltech e6x on 4ag 20v]
Cheers... jondee86
06-05-2013, 06:34 PM
For my 20V with MS DIYPNP and 4 Yaris COP's i'm using the 4 IGF signals to drive the tacho.
Keeping the AE86 alive!
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 2,238 05-26-2024 07:40 PM
Last Post: totta Crolla
  Running issues sam3007 6 2,782 06-26-2022 01:34 PM
Last Post: Dave W
  Question about 4AG 20v Engine Block CHACAMAN 1 1,618 06-10-2022 05:17 PM
Last Post: oldeskewltoy
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 10,983 02-10-2020 06:39 PM
Last Post: Power_uP
  What suspension set up are people using? kazi 8 8,083 07-06-2017 05:26 AM
Last Post: headrush
