the noby booth chronicles
07-01-2024, 09:20 AM
one of the best ae86's in the netherlands
07-01-2024, 10:18 AM
(This post was last modified: 07-01-2024 10:28 AM by r.ave.)
(07-01-2024 09:20 AM)ae86 forever Wrote: one of the best ae86's in the netherlands ![]() A nice car indeed, but i think you haven't seen half of all cars in the Netherlands. Check the dutch registrations list, it's somewhere here on the forum ![]() (06-12-2024 01:29 PM)livelaughlevin Wrote: the filter is finally on, i will be making a heat shield for it at some point but it will have to wait. I got some help from fellow 86 enthousiast Mike Pieffers who made inlet pipe. How has the sound changed after this airbox and filter compared to thea filtered stacks? ![]() |
07-03-2024, 07:44 PM
(This post was last modified: 07-03-2024 07:49 PM by livelaughlevin.)
(07-01-2024 10:18 AM)r.ave Wrote:(07-01-2024 09:20 AM)ae86 forever Wrote: one of the best ae86's in the netherlands it's hard to describe exactly but the sound is muffled like a trumpet under a blanket. It still has a nice growl though so I'm not dissatisfied. For a daily this is a 100% a must. I think the apex'i filter is an important factor in this observation. I am considering playing around with spacer plates inside the box both for structural integrity and to fine tune the trumpet length to see if I can retrieve some more of the sound and low end power (even though it's acceptable as it is now) (07-01-2024 09:20 AM)ae86 forever Wrote: one of the best ae86's in the netherlands thx man! it's not done at all, maybe i'm worthy of that title in 10 years or so ![]() |
07-04-2024, 04:06 PM
(This post was last modified: 07-04-2024 04:06 PM by Bean.)
Far from a final answer (as it does not exist anyway) but still somewhat interesting https://youtu.be/G8L9_XO3iCw?si=huoffgJbNtVCFMr_
AE86 ex-daily |
07-08-2024, 12:01 AM
(07-04-2024 04:06 PM)Bean Wrote: Far from a final answer (as it does not exist anyway) but still somewhat interesting https://youtu.be/G8L9_XO3iCw?si=huoffgJbNtVCFMr_ Yeah it's interesting to see test like this. I am pleased with the power the car makes now and I do feel better knowing that I won't blow up the engine of I drive through a patch of sand. I still intend to do quite a bit of experimenting with the current setup, first on the list is an aluminium box to shield the filter from hot engine bay air. Then I will try to add a spacer plate to make the stacks slightly longer (which may or may not make a significant difference in "feel") and give some structural integrity to the baseplate (it's warping from the pressure the long bolts put on it) |
