thermostat
07-26-2007, 01:53 PM
thermostat
hi
i done the whole headswap and all everthing is 100%
but now i repaceing my thermostat but wheni i install it ,it doesnt work and my fan does go on and the car overheats its as if the thermo is not opening
can any help
07-26-2007, 02:29 PM
thermostat
test the thermostat outside inside a tin of water and progressively heat it.
see if the thermostat opens/closes.
It could also be a wiring problem...
Keeping the AE86 alive!
07-27-2007, 08:27 AM
thermostat
i dropped it in warm boiling water but nothing happens i then decided to run boiling water over it but still nothing is it the thermostat then
i just bought i t
07-27-2007, 08:35 AM
thermostat
ok i just double checked it now again when tunning boiling over it does open and when running cooling it down it closes...so where can i look for this prob
could it by wiring as my fan don go on but when i unplug the fan plug/swith it goes ...
  Permanent oil cooler vs thermostat Lt86 19 21,818 03-28-2015 06:54 PM
Last Post: Lt86
  ae92 external thermostat housing plumbing? danny 86 2 5,235 08-15-2013 12:38 AM
Last Post: fax0815
  TE71: 2T-B engine thermostat opening temperature ? Ryo 1 3,689 04-06-2011 07:28 PM
Last Post: Ryo
  Thermostat removal - possible issues Ivan141 9 13,268 11-28-2005 05:19 PM
