thermostat
07-26-2007, 01:53 PM
thermostat
hi
i done the whole headswap and all everthing is 100% but now i repaceing my thermostat but wheni i install it ,it doesnt work and my fan does go on and the car overheats its as if the thermo is not opening can any help |
07-26-2007, 02:29 PM
thermostat
test the thermostat outside inside a tin of water and progressively heat it.
see if the thermostat opens/closes. It could also be a wiring problem... Keeping the AE86 alive! |
07-27-2007, 08:27 AM
thermostat
i dropped it in warm boiling water but nothing happens i then decided to run boiling water over it but still nothing is it the thermostat then
i just bought i t |
07-27-2007, 08:35 AM
thermostat
ok i just double checked it now again when tunning boiling over it does open and when running cooling it down it closes...so where can i look for this prob
could it by wiring as my fan don go on but when i unplug the fan plug/swith it goes ... |
Permanent oil cooler vs thermostat | Lt86 | 19 | 21,423 |
03-28-2015 06:54 PM Last Post: Lt86 |
ae92 external thermostat housing plumbing? | danny 86 | 2 | 5,172 |
08-15-2013 12:38 AM Last Post: fax0815 |
TE71: 2T-B engine thermostat opening temperature ? | Ryo | 1 | 3,651 |
04-06-2011 07:28 PM Last Post: Ryo |
Thermostat removal - possible issues | Ivan141 | 9 | 13,091 |
11-28-2005 05:19 PM Last Post: nmwisima |
