toyota a series engine....can a fwd corolla engine be used
10-29-2013, 07:07 PM
i have a general tech question
can any of the fwd corolla engines or mr2 motors be mounted to a rwd transmission?
if possible what years and part combinations work together best?
any tips, links, and wisdom is appreciated
10-29-2013, 07:30 PM
do you mean the 4AGE or other 4 type engines?
If 4AGE redtop then yes but you will need to do some modifications
intake needs to changed
water and oil routes
and flywheel
10-29-2013, 07:44 PM
actually i was under the impression that all 4 a block or parts were interchangeable depending on era
i dont have acess to a 4age and wanted to know options with other corollas/mr2 parts to build a naturally aspirated setup non turbo
is their a parts interchange link any where?
10-29-2013, 10:16 PM
mr2 mk1's only came with 4AGE engines AFAIK, they should fit if you have the necessary RWD bits.
Only other A series engines will fit the T50 gearbox, and none of them is really worth bothering with. A 4AFE is not too bad, but why spend money on such pursuits.. better to just drop in some non-toyota engine/box combination.
10-30-2013, 11:18 PM
The 7AFE to 7AGE modification could be an option though. Wink
[Image: AEU86 AE86 - toyota a series engine....c...ne be used]
Wink Can Wing Mirror Glass be Replaced? chrisae86 1 1,126 03-05-2023 09:34 PM
  Can you convert your 86 back too the original state? gh0st 7 2,696 04-25-2022 04:25 PM
Last Post: gh0st
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 7,660 12-19-2021 11:58 PM
Last Post: gh0st
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,267 09-08-2021 12:48 PM
Last Post: Ryo
  can i just slam a oem turbo on it ? MC_JP 3 5,933 12-17-2014 11:04 PM
