tps codes
08-01-2010, 03:05 PM
tps codes
ecu is showing code 7 and code 9 both throttle position sensor issues.
I have set this as per the manual and no codes showing, however I cannot get the ecu to go into diagnostic mode and the timing does not advance properly. I have also set it with the engine running, turning the tps until a change of revs happens (idle map ?) it then shows the 2 codes above. Any ideas ? An analogue brain in a digital World |
TPS and stop screw set up | kazi | 7 | 9,332 |
04-23-2017 09:40 PM Last Post: kazi |
TRD N2 color codes | ellinas82 | 1 | 7,016 |
07-19-2015 10:45 PM Last Post: Project D |
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 11,425 |
10-25-2013 05:13 PM Last Post: Apsogos |
TPS for carbs | totta Crolla | 7 | 7,852 |
01-30-2013 09:14 PM Last Post: totta Crolla |
TPS 89452-12090 | gjuro | 2 | 5,399 |
05-12-2010 12:41 AM Last Post: isac |
