tps codes
08-01-2010, 03:05 PM
tps codes
ecu is showing code 7 and code 9 both throttle position sensor issues.
I have set this as per the manual and no codes showing, however I cannot get the ecu to go into diagnostic mode and the timing does not advance properly.
I have also set it with the engine running, turning the tps until a change of revs happens (idle map ?)
it then shows the 2 codes above.
Any ideas ?
  TPS and stop screw set up kazi 7 9,332 04-23-2017 09:40 PM
Last Post: kazi
  TRD N2 color codes ellinas82 1 7,018 07-19-2015 10:45 PM
Last Post: Project D
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 11,428 10-25-2013 05:13 PM
Last Post: Apsogos
  TPS for carbs totta Crolla 7 7,852 01-30-2013 09:14 PM
Last Post: totta Crolla
  TPS 89452-12090 gjuro 2 5,400 05-12-2010 12:41 AM
Last Post: isac
