track questions:max oil/water temp,egt and other
07-05-2012, 05:47 PM
I have bought a small lcd unit which can display oil temp,water temp,egt,...
It is also possible to set an alarm at certain temps.
what would be the max safe temperatures?
oil temp:110 degrees?
water temp:90 degrees?
egtConfused
also with my new ring and pinion its very loud(was redone twice at a shop)
and i will keep the 4.7 like it is now until i have the 4AGZE and i will go back to 4.3
But for now what would be good sound dampening material for the loud whining?(highway is hell)
07-05-2012, 10:24 PM
I'll go WOt until i'll get the 120° on oil.
at that temp i self limit my shift up to 6500/7000 rpm to not go over than that temp.
I run Shell Helix 10w40 oil.
SR Team
BURN THE RUBER NOT YOUR SOUL!
07-05-2012, 10:39 PM
ditn Wrote:also with my new ring and pinion its very loud(was redone twice at a shop)
dynamat
Alot of people in the usa use this stuff. It's expensive but you can probably find a cheaper alternative on ebay.
With the r&p, when driving at highway speed (120kmph) at how much rpm is that?
ハチロク
[Image: AEU86 AE86 - track questions:max oil/wat... and other]
07-05-2012, 10:48 PM
@BOOMEX
thanks for the tip,i will add a bit more safety arround 110 115 then Smile
I run total 10W40 because thats what the previous runner was using for a long time.
WHat about water temp?
@zenki
i will check it out thanks
its not the rpm thats bothering me,im used to high rpm.
Its the loud whining.
for the rpm i will need to check but i think 4700 or so?
07-05-2012, 11:05 PM
Yea i know you're talking about the whining. I just asked the rpm question because i'm also buying the r&p.
ハチロク
07-06-2012, 01:35 AM
Oil temp:
mineral or blended: 110°C, after that you can get some trouble (depending of the brand/quality)
For full synthetic, you can go up to 120°C.
But I will strongly recommand to run a oil cooler and keep your oil temp near 100°C.
PS: Total activa 7000 = best way to get tons of black deposits...
Save your engien, get a better oil than that sh*t !
Water temp: 90°C is ok
EGT: 750°C/800°C max
07-06-2012, 12:40 PM
@zenki
I can tell you now its better to save a bit more and get the toyota oem 4.778.
We reset the r&p 3 times and we had no luck,whiny as hell.
Unless you don't care for the whining but highways is almost impossible to do due to the whine.
@project d
thanks for the info
ae86 has standard an oil cooler,so thats a big plus Smile
i dont know what total activa? is but i use total quartz 7000 10w40
I have been thinking about full synth but the engine had been running 100000+km on total quartz 10w40(250 000 km) so it can't be that bad?
Still going strong on the circuit.
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 2,046 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 955 04-30-2024 09:46 PM
Last Post: Mylesmck
  Anyone got Max Orido's Magical Fuse? banpei 7 3,218 02-08-2024 11:09 AM
  Wide Track 86 Mylesmck 8 2,297 05-28-2023 09:51 PM
  Brake Bias Questions mad.matt 10 11,113 01-03-2019 04:54 AM
