up and down oil pressure
05-10-2005, 03:23 PM
With the fine weekend that it was ,my friend brought out the coupe from hidden for a run.
but during this time realised that the oil pressure was fluctuating and was generally floating on the low side. Any ideas what the problem is?i dont think its to good any way |
05-10-2005, 07:19 PM
loose connector
05-10-2005, 08:01 PM
where bouts is the connector for the ol pressure sesnor?
Ya it probably is that case there is not smoke or any other problems |
05-11-2005, 10:04 AM
front of the engine block on the exhaust side...there is a small metal dome there with a protruding round "button". The connector should slide over that..it's a common problem...scared the shit out of me twice so far..
05-11-2005, 10:54 AM
hehe found out about this when cleaning the engine...I knocked it off the engine and couldn't figure out where it should connect. Took me 10 minutes to figure it out.
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,354 |
Oil Pressure Query | Alex170984 | 2 | 5,256 |
12-11-2014 01:25 AM Last Post: Alex170984 |
trans oil, lsd oil change | Apolan | 9 | 17,309 |
Pressure gathering in fuel tank | Apolan | 9 | 15,126 |
05-18-2014 06:18 AM Last Post: chenfon |
Engine revs up/down on its own | El_Camino | 8 | 14,268 |
04-27-2014 05:49 PM Last Post: Apsogos |
