upgrading brake system
05-14-2012, 02:07 PM
big Thanks to all of you guys
fax0815
bozu
aussiefan
sadziak
[Walaki]D`Lair
I think i will go with this solution :
sadziak Wrote:hi have done the conversion.
i recommend it a lot.
you need:
- Mazda FD3S 4 pot calipers - should track them on UK Ebay for about 90-120GBP) - depends on condition,
- good brake pads, mintex High Performance, Ferodo DS, Tarox, hawk HPS - you name it..
- good steel braided brake lines - i have HEL, you can buy also Goodridge,
- good high temp = high performance braking fluid (RBF 660),
- caliper mounting adaptors - you can buy them on ebay from USA (about 150usd+shipment+taxes...they come in aero-grade billet aluminum, very strong and very light with bolts 10.9 grade to mount them - should work plug and play) or you can dig the 4age forum for a CNC Machine Drawing file and try to make them in a local CNC Shop, but i assume they will not be much cheaper to do a single pair.
- new Mini Cooper S Rotors (272mm) - need to be redrilled at a workshop to fit, i recommend the ATE POWERDISCS (sloted) - good price for the performance, but you can also go for Tarox Sport Japan or DBS from Austraila if you have the money...$$
- bigger = more efficient braking Servo!! try important, you will not have enough braking power for the 4 pot calipers if you don't have a bigger braking servo!! a servo from a NISSAN 200SX s13 will do the job!
thats it, thats All.
Thumbs up! Hurray!
05-14-2012, 07:55 PM
sadziak Wrote:Walaki - Could you say something about The rear conversion? Have you done it, what calipers, disc did you use etc?
I have Corolla E12 TS rear calipers at the back, almost plug and play, and Primera P11 discs (257*11, 4*114.3). These calipers does not have handbrake pulleys, so its only good for hydraulic e-brake.
05-14-2012, 07:59 PM
And I dont have good experience with the ATE power disc, I think mine are warped after two trackdays on the Hungaroring. On our everyday/my girlfriends car (Ford Focus) we have Brembo Maxx discs, and I think I'll change the ATEs to those too.
And also if you'll go with the RX7 brakes at the front and Golf4 / Corolla E12 at the rear, I would recommend some bigger brake master cylinder aswell. Like RX7 or EVO8 or Supra MK3...
05-14-2012, 09:30 PM
Thanks a lot!! I will probably do The rear + hydro e-Break this summer Or during The winter. I have The servo - master cylinder from a 200sx s13 and it Does The job.
YO!
05-15-2012, 02:13 AM
Wich exactly primera p11? - The 2,0 16v GT 150hp/ p11.144?
YO!
05-15-2012, 02:16 AM
Will this one be ok? http://www.iparts.pl/czesc/tarcza-hamulc...00015.html
YO!
05-15-2012, 09:19 AM
sadziak Wrote:Wich exactly primera p11? - The 2,0 16v GT 150hp/ p11.144?
yes
05-19-2012, 09:58 PM
I have uprated Ford Falcon XR8 front brakes ( 4Pot) with slotted discs
http://www.herrodmotorsport.com.au/Porta...Falcon.jpg
05-20-2012, 12:12 AM
Quote:I have uprated Ford Falcon XR8 front brakes ( 4Pot) with slotted discs
They are only 2 pot floating calipers
05-20-2012, 01:12 AM
So they are teach me to cut copy paste
  Stack display system, need help Jimmi The Kid 1 4,255 01-15-2017 10:52 PM
  How to rebuild the AE86's brake system all around Homem Bomba 7 13,813 07-02-2013 10:31 PM
Last Post: Homem Bomba
  Who has a Kakimoto R Exhaust system? Rick 4 7,760 06-19-2013 09:11 AM
Last Post: Mint_86
  Fuel system setup 86Pilot 2 4,722 01-30-2013 04:24 PM
  How does the 4age AFM system work? heshan 22 23,790 12-20-2012 05:01 AM
Last Post: heshan
