upgrading brake system
05-10-2012, 09:55 PM
aussiefan Wrote:RX7 FC or FD - the calipers are almost the same, just some optical differences. Hi, there is a difference between FC and FD. FD are from Aluminum and are much much lighter! hi have done the conversion. i recommend it a lot. you need: - Mazda FD3S 4 pot calipers - should track them on UK Ebay for about 90-120GBP) - depends on condition, - good brake pads, mintex High Performance, Ferodo DS, Tarox, hawk HPS - you name it.. - good steel braided brake lines - i have HEL, you can buy also Goodridge, - good high temp = high performance braking fluid (RBF 660), - caliper mounting adaptors - you can buy them on ebay from USA (about 150usd+shipment+taxes...they come in aero-grade billet aluminum, very strong and very light with bolts 10.9 grade to mount them - should work plug and play) or you can dig the 4age forum for a CNC Machine Drawing file and try to make them in a local CNC Shop, but i assume they will not be much cheaper to do a single pair. - new Mini Cooper S Rotors (272mm) - need to be redrilled at a workshop to fit, i recommend the ATE POWERDISCS (sloted) - good price for the performance, but you can also go for Tarox Sport Japan or DBS from Austraila if you have the money...$$ - bigger = more efficient braking Servo!! try important, you will not have enough braking power for the 4 pot calipers if you don't have a bigger braking servo!! a servo from a NISSAN 200SX s13 will do the job! thats it, thats All. YO! |
Messages In This Thread |
upgrading brake system - AE86-SA - 05-05-2012, 01:08 AM
[] - sadziak - 05-10-2012 09:55 PM
[] - [Walaki]D`Lair - 05-13-2012, 11:11 AM
[] - [Walaki]D`Lair - 05-13-2012, 12:25 PM
[] - [Walaki]D`Lair - 05-14-2012, 07:55 PM
[] - [Walaki]D`Lair - 05-14-2012, 07:59 PM
[] - [Walaki]D`Lair - 05-15-2012, 09:19 AM
[] - Eircamae86 - 05-20-2012, 02:25 PM
[] - [Walaki]D`Lair - 05-20-2012, 03:44 PM
Stack display system, need help | Jimmi The Kid | 1 | 4,181 |
01-15-2017 10:52 PM Last Post: Ivan141 |
How to rebuild the AE86's brake system all around | Homem Bomba | 7 | 13,519 |
07-02-2013 10:31 PM Last Post: Homem Bomba |
Who has a Kakimoto R Exhaust system? | Rick | 4 | 7,658 |
06-19-2013 09:11 AM Last Post: Mint_86 |
Fuel system setup | 86Pilot | 2 | 4,657 |
01-30-2013 04:24 PM Last Post: Bean |
How does the 4age AFM system work? | heshan | 22 | 23,460 |
12-20-2012 05:01 AM Last Post: heshan |
