valve tick on cylender two intake
12-15-2014, 05:52 AM
Post: #31
Just ordered both testers and will run both. When I do the comp test will I want to turn the crank pully as fast as possible?
12-15-2014, 09:52 AM
Post: #32
(12-15-2014 05:52 AM)dinkers542 Wrote:  Just ordered both testers and will run both. When I do the comp test will I want to turn the crank pully as fast as possible?
the compression tester has a oneway valve so just turn it gradualy a couple of times untill the gauge isn't going substantialy higher anymore. Apart from reaching the minimum spec you'll also want the cylinders to be even (less than 1bar/14psi difference)
AE86 ex-daily
  4AGE Valve Buckets Scored Steller Engineering 2 971 10-06-2023 05:34 PM
Last Post: Steller Engineering
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,485 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,312 05-25-2022 10:24 PM
Last Post: oldeskewltoy
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 17,712 08-16-2018 01:36 AM
  Valve clearance leon205gti 7 8,810 11-25-2016 03:24 AM
