water leakage in the trunk RHS ??
03-25-2008, 03:16 PM
Heey
Is it common for a AE86 coupé to have water leakage in the trunk, cause I dont know where the water is comming from yet!! Try to make some pictures tonight or tomorrow.. my sugestions are: *rear side glass RHS * rear window somewhere in that direction I suppose... I dont think that I am the only one with this problem.. am I ? Cheers Roel |
03-25-2008, 04:01 PM
Usually this leak comes from the rear glass on the hatch - rust forms on the metal seam as it leaks through.... You can have some moderate success using find a leak sealant... Or use clear silicone sealant against the rubber seal / glass.
It also happens with FRP boot lids (Although sealant helps). We find the best way to stop water getting in is to cover the car with a cover, or put it in a garage when not in use.. VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
03-25-2008, 04:28 PM
had a look at the rear ligths yet?
03-25-2008, 04:57 PM
yeah, looked at the rar lights.. But that seemed dry.. have to check it when the car is in stand...
maybe I will Flip the rear seat and crall in while someone is getting the outside of the car wet.. but this is not that nice weather to preform that.. I will remove the rear light first and check unterneath.. like It.. best way to stop water... Put it in a garage.. are you going to build it for me.. no, that is not the solution to atack the cause of the problem. but would be nice though... cheers roel |
03-26-2008, 05:34 PM
Check the rubber trunk seal: mine leaked a littlebit through it because the seal was getting old. I used some grease to "renew" the inside of the seal.
03-26-2008, 08:50 PM
where back lights are attached to body ,on top of light ,when car wet and u open boot door water can seek in i have mine sealed up all roung lights
03-27-2008, 01:50 AM
2x paul--86! i really need to sort that problem out also.
03-27-2008, 12:01 PM
I went drifting for a whole day on a wet course. Halfway through the day my spare tire space was FULL with water!
I just took out the rubber fittings on the sides of the trunk so that all water could escape. Had no problems ever since. |
03-27-2008, 07:02 PM
hmm..
not so nice.. I want my trunk to be watter-free for little audio . cheers Roel |
03-27-2008, 08:40 PM
C'mon guys stop with the lame excuses, rain leak here, rain leak there and just [u:5aebfd1b87]ADMIT IT![/u:5aebfd1b87] You're all spilling your tofu aren't you?!
Trunk and fuel door cable | pack | 2 | 7,055 |
04-23-2018 11:01 PM Last Post: pack |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 7,718 |
12-06-2017 06:48 PM Last Post: Bean |
20v conversion water relocation | izanagi | 1 | 5,501 |
06-15-2016 09:45 AM Last Post: banpei |
Rust in trunk | AnthonyStallone | 11 | 14,189 |
02-18-2015 06:23 PM Last Post: Bean |
20v with 16v Water Relocation Kit | D.O | 9 | 16,110 |
06-12-2014 02:48 AM Last Post: jondee86 |
User(s) browsing this thread: 15 Guest(s)
