water leakage in the trunk RHS ??
03-25-2008, 03:16 PM
Heey
Is it common for a AE86 coupé to have water leakage in the trunk,
cause I dont know where the water is comming from yet!!
Try to make some pictures tonight or tomorrow..
my sugestions are:
*rear side glass RHS
* rear window
somewhere in that direction I suppose...
I dont think that I am the only one with this problem.. am I ?
Cheers Roel
03-25-2008, 04:01 PM
Usually this leak comes from the rear glass on the hatch - rust forms on the metal seam as it leaks through.... You can have some moderate success using find a leak sealant... Or use clear silicone sealant against the rubber seal / glass.
It also happens with FRP boot lids (Although sealant helps).
We find the best way to stop water getting in is to cover the car with a cover, or put it in a garage when not in use..
VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
03-25-2008, 04:28 PM
had a look at the rear ligths yet?
03-25-2008, 04:57 PM
yeah, looked at the rar lights.. But that seemed dry.. have to check it when the car is in stand...
maybe I will Flip the rear seat and crall in while someone is getting the outside of the car wet.. Big Grin
but this is not that nice weather to preform that..
I will remove the rear light first and check unterneath..
like It.. best way to stop water... Put it in a garage..
are you going to build it for me.. Big Grin
no, that is not the solution to atack the cause of the problem. Big Grin
but would be nice though...
cheers roel
03-26-2008, 05:34 PM
Check the rubber trunk seal: mine leaked a littlebit through it because the seal was getting old. I used some grease to "renew" the inside of the seal.
[Image: AEU86 AE86 - water leakage in the trunk RHS ??]
03-26-2008, 08:50 PM
where back lights are attached to body ,on top of light ,when car wet and u open boot door water can seek in i have mine sealed up all roung lights
03-27-2008, 01:50 AM
2x paul--86! i really need to sort that problem out also.
03-27-2008, 12:01 PM
I went drifting for a whole day on a wet course. Halfway through the day my spare tire space was FULL with water! Huh
I just took out the rubber fittings on the sides of the trunk so that all water could escape. Had no problems ever since.
03-27-2008, 07:02 PM
hmm..
not so nice.. I want my trunk to be watter-free for little audio . Wink
cheers Roel
03-27-2008, 08:40 PM
C'mon guys stop with the lame excuses, rain leak here, rain leak there and just [u:5aebfd1b87]ADMIT IT![/u:5aebfd1b87] You're all spilling your tofu aren't you?! Tongue
  Trunk and fuel door cable pack 2 7,055 04-23-2018 11:01 PM
Last Post: pack
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 7,718 12-06-2017 06:48 PM
  20v conversion water relocation izanagi 1 5,501 06-15-2016 09:45 AM
  Rust in trunk AnthonyStallone 11 14,189 02-18-2015 06:23 PM
  20v with 16v Water Relocation Kit D.O 9 16,110 06-12-2014 02:48 AM
Last Post: jondee86
User(s) browsing this thread: 13 Guest(s)
