what is needed
05-31-2006, 02:44 AM
what is needed
exactly to put the following on a KE70:
rear shocks and springs from AE86 Front shocks and springs from an ae86 front brakes from ae86 can all the above be done seperately? |
05-31-2006, 12:16 PM
what is needed
dude you need to speaketh to Simon86 from dworks
anyway need front struts and steering arms off an ae86 as the ke 70 too short the rears are pretty much the same jsut no parnhard rod mounting points. |
05-31-2006, 01:17 PM
what is needed
not too much then
just struggling to find a way i can pick the car up atm |
06-01-2006, 11:13 AM
what is needed
Hi dude,
there are mounting points for the panard rod on the KE70 rear axel, I think Oli was confussed with that there are no points to put the rear ARB that is found on the a86. Bothe the KE70 and the AE86 are both 5 linked rear axels, and are the same. Best bet for suspension Ben, would be to get a poly bush kit, a set or rear uprated shocks and springs form an ae86, then, ge hold of a set of hubs, calipers, discs, the front struts from an AE86 and the steering arms. I belive (not sure yet) that the ae86 rack make more lock but will find out when I fit mine! Strut braces will fit from an Ae86 aswell. If you plan to 4age it, you will need a 4AGE, and T50 gearbox, AE86/or TE71 1600 Xmember, gearbox mount, propshaft from an AE86, and a early spec AE86 diff, as thesefit into the KE axel. You will also need to sort the Clutch on the t50 box too, as the T50 uses a hydrolic clutch, but the k series gearbox in the KE uses a cable. id say, sort your suspension out and worry about the engine later, see how you get on etc. Oh and weld the std diff. 1980 Toyota Corolla KE70 DX 1983 Levin GTV |
06-02-2006, 03:03 PM
what is needed
smart arse
06-02-2006, 04:18 PM
what is needed
oli Wrote:smart arse hehehe !! here, look at this,it is also useful. http://www.rollaclub.com/faq/index.php?t...ing_to_RWD 1980 Toyota Corolla KE70 DX 1983 Levin GTV |
06-02-2006, 04:27 PM
what is needed
thakns a lot for that mate
think im gonna do the cheap and easy firts lol. rear springs and shocks, weld the diff. saw some nice 4x100 13x10 alloys too need them spacers you about tonight? need to give you a ring re: the car |
06-08-2006, 02:04 PM
what is needed
it's should be sweet with 10x13, depends on the offset, shouldn't need spacers. but with 4x100 pcd
i still haven't decided what to do with my KE, i have got the 4 links with DW poly bushed & adj panhard rod, zenki diff and shalf, prop, t50, engine, complete looms and ECU, clutch and flywheel and some other bits come off my AE. i just don't have the time and money. those parts maybe up for grab once i decide. LONG LIVE TOYOTA!! |
