what rack and pinions are compatible ae86
07-27-2008, 06:39 AM
What rack and pinions are compatible for a ae 86, unsure about year, could be 85 or 86, its said to be a 85, no vin plate
I found a 82 or 83 or 80 corolla I cant remeber, but it has a 4ac in it, unsure about PS, mine has PS, but i need steering and I can get it for like 40, so I dont know. Does any one know if its compatile?
Thanks?
Also any one know where I can find rear end ratios for the lsd gts cars and manual transmissions.
1985 300ZX Turbo 5spd < The only one that drives.
1985 Corolla not Turbo 5spd <- The only one with live axle.
1976 280Z Turbo 4spd <- The only one without an LSD.
07-27-2008, 10:18 AM
You can use a rack out of an AE71 corolla, though apparently has one less tooth on the manual rack.
Not aware if they came with power steering though. Certainly didn't in Australia.
07-27-2008, 11:06 AM
Thanks for the quick reply. What years are AE71, I read that they were a cheaper version of the ae86, but im not sure if the US got them, I never heard of them.
I don't care about PS right now, it has a pump but its not all there so Ill worrie about that when the car is driving. I would just like to be able to steer... I figure if I can fix it for 25 and not have PS(it wouldn't work any way) then its all good.
This car has a PS cooler doesn't it? If so, do the SR5s come with those too or just the GTS?
07-27-2008, 05:13 PM
aw11 mr2 manual racks are exactly the same
07-28-2008, 02:30 AM
mc68 Wrote:aw11 mr2 manual racks are exactly the same
thats like a 88 year? correct? I pulled one out at the junkyard and put them side by side and the mr2 is much longer and is not PS.
All they had as far as a corolla was a 4ac corolla from like 82 or 83 so I got that, it was 25 bucks, it looks like it should work. Its manual.
07-31-2008, 01:25 PM
Got the steering all done, used the manual rack from earlie 80s corolla and had to use its intermediate shaft(or whatever), and its U-joint since the rack input thing was smaller... was a pain, if any one has done this with the motor in the car and didnt pull out the steering column then they have skills, I dont see how you can do it without pulling the steering column out.
and the manual brackets on the passenger side were shorter(dont know what people do about that, maybe I got them from a weird year or something) but I cut out to the ends to make like a slot and it worked... Ill definatly convert back to PS when the car is in better shape.
Thanks for the help finally got to drive my car around my yard(just to move it from where it was jacked up being worked on, it needs new tires it has 1 flat... but I can get 15 inch tires for free so no biggie.
08-12-2008, 06:08 AM
Old Corolla's and Celica's work. The MR2 AW11 needs a conversion kit to work properly.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 6,786 07-31-2019 11:28 AM
  Quaife quick rack totta Crolla 19 20,919 03-03-2018 03:32 PM
Last Post: Deuce Cam
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 43,160 10-02-2014 06:07 PM
  Play in power steering rack help phill 92 5 6,436 10-25-2012 12:01 PM
Last Post: allencr
  Rack end Sanity Clause 1 3,410 04-25-2012 05:32 PM
Last Post: Sanity Clause
