what tires size do i need?
05-26-2012, 01:24 PM
hi, i have bought some new rims. rota BM8 15inch 9j.
what tire size do i need for this?
this are the rims.
[Image: AEU86 AE86 - what tires size do i need?]
05-26-2012, 01:28 PM
I put 195/50/15 on them, use them on the back for drifting. I also tried stretching 195/45 on them but the sidewall was too stiff. Now i got 215/40/15 on them for track use.
No Smorking AE86
05-26-2012, 06:51 PM
205/45/15 Wink
SR Team
BURN THE RUBER NOT YOUR SOUL!
05-26-2012, 10:58 PM
225-45-15 is the only correct size Smile
05-27-2012, 12:34 AM
NoHachi Wrote:225-45-15 is the only correct size Smile
+1
05-27-2012, 09:49 AM
thanx. i am think about 215/45R15 or 225/45R15. do someone have pictures of this? (sorry for my bad enlisch)
05-27-2012, 06:36 PM
225/45 (look on 16")
215/45 (on 15")
05-27-2012, 09:50 PM
Different manufacturers and models of tyres are different width, so you should search the net for models you are planning.
Ive seen some 205 tires that are wide as others 235. Toyo and Falkens are often thinner then rest. Conti and Michelin are right size, when measured.
But i agree with NOT going tyrestretch. Looks are often not related to performance and safety.
05-28-2012, 08:28 AM
would 225/50R15 be to high? i thinking of 225 or 215 tire size
thanx oldskull for the pictures
05-28-2012, 09:26 AM
I think it would, and that it would look ugly.
225/45 is already big tire, diameter with 15" is slightly larger than stock tires, you should not go bigger profile.
  Winter tires Ryo 7 5,246 01-30-2020 05:33 AM
  Shim size for AM cams kazi 4 5,155 12-18-2017 05:34 PM
Wink Hub size kazi 5 9,599 06-09-2017 10:06 PM
Last Post: kazi
  Camshaft sprocket bolt size? harkes 1 4,609 07-03-2015 12:41 PM
Last Post: Dave W
  (Video) Tips to choose a good set of tires Homem Bomba 1 4,167 07-22-2013 04:59 PM
Last Post: Homem Bomba
