what tires size do i need?
05-26-2012, 01:24 PM
hi, i have bought some new rims. rota BM8 15inch 9j.
what tire size do i need for this? this are the rims. ![]() ![]() toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
05-26-2012, 01:28 PM
I put 195/50/15 on them, use them on the back for drifting. I also tried stretching 195/45 on them but the sidewall was too stiff. Now i got 215/40/15 on them for track use.
No Smorking AE86 |
05-26-2012, 06:51 PM
205/45/15
![]() SR Team BURN THE RUBER NOT YOUR SOUL! |
05-26-2012, 10:58 PM
225-45-15 is the only correct size
![]() A wheel to steer the front of the car A pedal to steer the rear |
05-27-2012, 12:34 AM
NoHachi Wrote:225-45-15 is the only correct size +1 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
05-27-2012, 09:49 AM
thanx. i am think about 215/45R15 or 225/45R15. do someone have pictures of this? (sorry for my bad enlisch)
05-27-2012, 06:36 PM
225/45 (look on 16")
![]() 215/45 (on 15") ![]() 1985 AE86 (ハチロク) Levin - Summer time daily driver |
05-27-2012, 09:50 PM
Different manufacturers and models of tyres are different width, so you should search the net for models you are planning.
Ive seen some 205 tires that are wide as others 235. Toyo and Falkens are often thinner then rest. Conti and Michelin are right size, when measured. But i agree with NOT going tyrestretch. Looks are often not related to performance and safety. |
05-28-2012, 08:28 AM
would 225/50R15 be to high? i thinking of 225 or 215 tire size
thanx oldskull for the pictures toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
05-28-2012, 09:26 AM
I think it would, and that it would look ugly.
225/45 is already big tire, diameter with 15" is slightly larger than stock tires, you should not go bigger profile. |
Winter tires | Ryo | 7 | 4,846 |
01-30-2020 05:33 AM Last Post: oldeskewltoy |
Shim size for AM cams | kazi | 4 | 4,947 |
Hub size | kazi | 5 | 9,172 |
06-09-2017 10:06 PM Last Post: kazi |
Camshaft sprocket bolt size? | harkes | 1 | 4,448 |
07-03-2015 12:41 PM Last Post: Dave W |
(Video) Tips to choose a good set of tires | Homem Bomba | 1 | 4,048 |
07-22-2013 04:59 PM Last Post: Homem Bomba |
