what wheel size 13", 14", 15" use on hachi ?
07-26-2006, 01:47 PM
Dont need to bent the lip to the outside you can do it inside so it looks good.
danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
07-26-2006, 02:39 PM
It will look better bent out since that will make the fender wider.. it also removes the flat edge on the fender if you do it right, so it will look rounder. As you can see in the pics some people are more talented at this than others.
Shim size for AM cams | kazi | 4 | 5,180 |
Hub size | kazi | 5 | 9,625 |
Camshaft sprocket bolt size? | harkes | 1 | 4,615 |
Oil plug thread size is M18x1.5 ???? | Dino86 | 5 | 9,410 |
what tires size do i need? | slowboy2 | 10 | 13,768 |
05-28-2012 09:26 AM Last Post: Uzelac |
