what wheel size 13", 14", 15" use on hachi ?
07-26-2006, 01:47 PM
Dont need to bent the lip to the outside you can do it inside so it looks good.
[Image: AEU86 AE86 - what wheel size 13&quot...on hachi ?] http://www.jdmbits.com
07-26-2006, 02:39 PM
It will look better bent out since that will make the fender wider.. it also removes the flat edge on the fender if you do it right, so it will look rounder. As you can see in the pics some people are more talented at this than others.
  Shim size for AM cams kazi 4 5,180 12-18-2017 05:34 PM
Wink Hub size kazi 5 9,625 06-09-2017 10:06 PM
Last Post: kazi
  Camshaft sprocket bolt size? harkes 1 4,615 07-03-2015 12:41 PM
Last Post: Dave W
  Oil plug thread size is M18x1.5 ???? Dino86 5 9,410 06-07-2012 04:54 PM
Last Post: Dino86
  what tires size do i need? slowboy2 10 13,768 05-28-2012 09:26 AM
Last Post: Uzelac
