wheels option: 15x7 +0 or 15x8 +15??
03-20-2008, 04:27 PM
Hi guys
I need some new wheels.
Since putting on the fc3s calipers in the front the 15" AITWE won't fit anymore without spacers (approx. 1cm needed).
Now I wanted to get some new wheels anyway.
What do you think is the better option:
15x7 offset 0
15x8 offset 15
I am aiming more towards the 15x8 since this might help for racing too.
But what do you think?
Cheers
Tobias
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: info@speed-industries.ch
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: info@speed-industries.ch
We have all the parts your Hachi needs
03-20-2008, 04:36 PM
7 off 0
perfect offset for an ae and you dont need to modify your arches or something.
if you want those 8 inches i would probably add a spacer of 10mm. Had my 7 inch +20 on my car in the past and they were extremely close to my coilovers. When cornering hard you could hear them scratch the coilover. 8 inch +15 will be even more toawards your strut. In my case impossible with the coilovers from T3.
[Image: AEU86 AE86 - wheels option: 15x7 +0 or 15x8 +15??]
03-20-2008, 10:11 PM
Strange. FC calipers must fit under 15" wheels ..... at least with Mini One rotors.
03-21-2008, 01:30 AM
jamie i think teh problem is with thickness/offset clearance not so much with the diameter..
03-21-2008, 02:05 AM
FC calipers under 15x7 0ET Konigs with 296 disc
http://www.ae86.hu
03-21-2008, 09:40 AM
I'll go with 7 ET0 but then again I have enhanced steering angle to clear... as you are more the racer go for 8s if they clear your suspension ... you still could fit some NCRCAs to get a bit more clearance, as your car is lowered anyway or like I will do ane day... some of these:
03-22-2008, 03:09 PM
Yeah that Nagisa is a sweet bit of kit.Yummie!
But also something for the future. There are a lot of things for the future though. Cool
Clearance problem happen not with the diameter but with rubbing on the inner side of the wheel due to offset.
I probably go for the 7" ones since the available semi slicks are not that wide anyway. Probably go for the new Advan A050, should be much better then the Toyos.
Speed Industries
8808 Pfaeffikon
Switzerland
03-22-2008, 06:11 PM
Fastest combination on track are probably the 225-50-15 kooks on the 15x8s. I think the toyos also come in that size. The new 195-50 RE01 stones also have such a wide footprint that they probably work better on a 8inch rim.
03-22-2008, 07:49 PM
I would get the 15x8 with a 20 or 25mm spacer.
You know you want it!!.
03-24-2008, 08:37 PM
XJS Wrote:FC calipers under 15x7 0ET Konigs with 296 disc
XJS, what car is 296 mm disk form ????
  RX7 Calipers with Rota Grid V ET0 15x8' pack 11 14,124 02-06-2015 11:28 AM
  seat option r.hellenbrand 5 7,259 06-29-2011 07:01 AM
Last Post: Super86
  Gear Box option - again? KD2229 11 16,218 11-27-2009 03:10 AM
Last Post: KD2229
  New rearend option available from VAC Motorsports killergtz 1 3,503 03-06-2009 06:05 AM
Last Post: killergtz
