AE85 Power! From 175HP 20v to 202HP F20
10-22-2011, 06:58 AM
(This post was last modified: 07-06-2014 01:30 AM by 4000GT.)
Pictures say it all... 175WHP (more to come), fairly extensive shopping cart.
Before... After... |
10-22-2011, 07:51 AM
nice work mate!!
give us some specs. |
10-22-2011, 08:26 AM
you did a great work
What are the spec of the engine? SR Team BURN THE RUBER NOT YOUR SOUL! |
10-22-2011, 08:33 AM
Excellent, amazing looking 86
An 86 is for Life, not just for Christmas |
10-22-2011, 09:12 AM
Oh geez specs, this will be a write up!
Engine: Custom header (SS 304 in 1.5" diameter primaries and 660mm long, to a full 2.5" SS 304 exhaust, DEI header wrap Custom Aluminium intake with CNC backing plate with built in 45mm velocity stacks. 3SGTE injectors Coil On Plug ignition Sliver top block (I grenaded a Black Top one) with balanced crank, ARP Bolts throughout, ACL bearings, Tomei rods, custom CP pistons, 15:1 CR. 288 degree 10mm lift Kelford Cams Supertech 1mm OS valves, Supertech Valve Springs Excedy Lightweight Flywheel Setrab oil cooler and TRD oil filter with HKS adapter off the block Moroso catch can (shortened to meet regs) with K&N filter Half size radiator with alloy shrouding and electric fan K&N 3" cone filter ARP alloy heat shield TRD oil cap TRD 0.8mm headgasket Rest of drive train T50 Gearbox TRD Short shift TRD 2 way LSD Redline oils throughout Braided clutch line Wheels and brakes 15X8 +10 offset rims with Toyo R88 205/50 rubber Wilwood Dynalight 4 pot brakes Wilwood brake pads Wilwood slotted and drilled rotors SS brake lines Nissan R33 brake booster Momo pedals Cusco brake booster stopper Body Fibreglass Front bumper, Bonnet, Front guards, Side Skirts, Rear hatch and Rear bumper Lexan MR10 rear hatch and side window glassing Racetech canvas toe hooks Seam welded Aerocatch bonnet pins New rear updated tail lights Plastic bolts used where possible Interior Flocked dash and door cards Digital Dash conversion Sabelt seats Bride seat rail (passenger) and custom alloy for driver Takata 6 point seat belts Innovate oil pressure and engine temp gauges Fuel pressure, oil pressure and water temp warning lights Momo steering wheel and Momo quick release hub kit T3 handbrake button USI cage padding Bride floor mats TRD gear knob TRD push start button ECU and fueling Vipec V44 custom looms (everything unnecessary removed) RCI fuel cell with level sender Custom surge tank and Bosch 910 pump Mr Gasket lift pump Suspension TRD shocks (short stroke) TRD springs (8kg front 6kg rear) Whiteline sway bars front and rear Tein camber plates T3 adjustable panhard rod T3 4 link adjustable rods T3 castor rods T3 Lower control arms T3 manual rack nolethane bushes 175WHP running aviation fuel. Road registered Thats all I can think of off the top of my head! |
10-22-2011, 09:13 AM
Eircamae86 Wrote:Excellent, amazing looking 86 Its an 85! Build to destroy 86's! mwahahahaha |
10-22-2011, 09:57 AM
Nice, how much does she weigh?
10-22-2011, 10:06 AM
Hard to say, I would think around 850kg? I will have to get it weighed sometime. The main issue remaining is the factory metal doors, they weigh 26kg each, I can cut that to 6kg with fibreglass doors!
10-22-2011, 10:19 AM
Engine bay lack of wiring is very tasty
10-22-2011, 01:47 PM
Veery nice looking classic AE86! Amazing work.
I was always wondering why there are not more people with a propper airbox on there stacks. Heat soaking and such... A airbox will always be better... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
Ae85 | Minidaxman | 4 | 3,459 |
04-20-2021 09:57 PM Last Post: banpei |
Sam's AE85 Conversion | Sambo | 2 | 14,465 |
05-20-2014 05:03 AM Last Post: Sambo |
Stalkers daily AE85 - 7AGE | stalker | 32 | 44,039 |
12-28-2011 02:28 PM Last Post: stalker |
Tofu's AE85 F20C Project | Tofu | 31 | 58,349 |
07-30-2011 10:58 PM Last Post: kennedy8383 |
Ricks project AE85 (Back together with dyno results) | Rick | 132 | 225,566 |
07-05-2011 11:54 AM Last Post: Rick |
