0-60
11-27-2011, 10:03 PM
7.36 to 60mph
16.12 quarter mile Good, bad or indifferent ? An analogue brain in a digital World |
11-27-2011, 10:43 PM
car and specs ?
edit: if it's a standard ae86, it's not bad at all '87 levin coupé |
11-27-2011, 11:32 PM
pretty much stock '86 apart from smallport engine and inlet with CatCams 260/266 cams.
All interior plus full rollcage and all steel panels. An analogue brain in a digital World |
11-28-2011, 01:08 AM
I did 6.0s flat with around 190hp, 5.3 with 250hp. So 7.3 is not shabby by any means. There should be more people around these days with cheap smartphones that can measure this stuff.
11-28-2011, 01:23 AM
i did 14.9.
that was with my TE71 with blacktop engine drift ae86:308bhp/435nmEDIT:384pk/498nm!!!!>now DEATH))) |
11-28-2011, 01:23 PM
NoHachi Wrote:I did 6.0s flat with around 190hp, 5.3 with 250hp. So 7.3 is not shabby by any means. There should be more people around these days with cheap smartphones that can measure this stuff. My 0-60 time is ok and probably because the car will do more than 60mph in 2nd gear with the cams. fitted. Quarter mile is not so good and possibly proves a lack of power low down. Times were taken from an accurate trip computer. A 5.3 would mean at least 2 gear changes ? Sub 15 seconds quarter mile An analogue brain in a digital World |
11-28-2011, 03:00 PM
totta Crolla Wrote:My 0-60 time is ok and probably because the car will do more than 60mph in 2nd gear with the cams. fitted.Cams don't change anything about speed ! The speed is based on: -the rev of your engine -the gear ratio (2.022 for the 2nd gear on a T50) -the final ratio (4.1 in Uk ?) -and the size of your tyres. Even with a weak 4AG, if it can rev over 7500rpm you can go over 60mph in 2nd |
11-28-2011, 07:20 PM
Well whilst the standard engine can rev to 7500rpm it is well past its peak power at what ? 6600rpm and 52mph ?
So cams can ensure the power is made further up the rev range and in this case allowing over 60mph in 2nd gear and still accelerating. Cams change quite a lot about speed :wink: The final drive of my U.K car is 4.3 An analogue brain in a digital World |
11-28-2011, 08:31 PM
you don't get my point but whatever....
11-28-2011, 08:35 PM
1/4 mile in 13secs flat, could be into 12s easily but street tires and short gearing let it down.
