16V ECU pinout on 20v swap
06-11-2015, 01:37 PM
Hey,
I'm almost getting my 20v swap over! But now i'm facing a huge question that the internetz can't solve.
I have on the C plug* Yellow on PIN #7 (The Black/Red wire) in the center of the plug
[Image: AEU86 AE86 - 16V ECU pinout on 20v swap]
The signal from the J/B4 on the manuals is the EFI main relay, the out put from the wire is a ECU terminal. Where does it connect?
Basically i have everything wired except this EFI pin that i have no idea where to connect it.
Can someone help me out?
Regards
06-11-2015, 06:41 PM
Whats the pin called on the 16V ECU? Is it +B and +B1? Than it should go to +B on the 20V ECU. It also seems to run the fuel pump via the circut opening relay.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
06-12-2015, 01:22 AM
Got it solved Big Grin
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 2,266 05-26-2024 07:40 PM
Last Post: totta Crolla
  20v swap bell housing izanagi 2 4,157 12-15-2016 01:12 PM
Last Post: pack
  20v swap alternator izanagi 3 4,978 12-15-2016 01:11 PM
Last Post: pack
  extracted freedom ecu 16v ignition map ditn 7 8,841 08-22-2016 10:01 AM
Last Post: ditn
  20v BT conversion ECU izanagi 5 6,827 06-14-2016 02:39 PM
Last Post: izanagi
