16V ECU pinout on 20v swap
06-11-2015, 01:37 PM
Hey,
I'm almost getting my 20v swap over! But now i'm facing a huge question that the internetz can't solve. I have on the C plug* Yellow on PIN #7 (The Black/Red wire) in the center of the plug ![]() The signal from the J/B4 on the manuals is the EFI main relay, the out put from the wire is a ECU terminal. Where does it connect? Basically i have everything wired except this EFI pin that i have no idea where to connect it. Can someone help me out? Regards |
06-11-2015, 06:41 PM
Whats the pin called on the 16V ECU? Is it +B and +B1? Than it should go to +B on the 20V ECU. It also seems to run the fuel pump via the circut opening relay.
06-12-2015, 01:22 AM
Got it solved
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 3,099 |
20v swap bell housing | izanagi | 2 | 4,423 |
12-15-2016 01:12 PM Last Post: pack |
20v swap alternator | izanagi | 3 | 5,297 |
12-15-2016 01:11 PM Last Post: pack |
extracted freedom ecu 16v ignition map | ditn | 7 | 9,406 |
20v BT conversion ECU | izanagi | 5 | 7,188 |
06-14-2016 02:39 PM Last Post: izanagi |
